The frets on my 25yr old Strat copy are very low and it makes bending difficult as there's hardly any fret height to use. I've never had a guitar re-fretted before so have no idea where to start - what type/size frets to use or how to compare. My other electric is a Gretsch Electromatic Dueo Jet centre block but I don't know what frets are on there other than they feel ok.
I don't know where to begin with choosing frets as I don't want to pay for a re-fret then find I don't get on with them or they make the guitar feel wrong.
Any suggestions of where to start? Or is it a case of going to a luthier and just beginning the conversation and getting their advice?
Changing the fret wire height will oblige you to replace the nut in order for the strings to have sufficient clearance. This, in turn, will alter the ride.
Removal of the original frets present an opportunity to have the fingerboard planed for a flatter radius. This, too, would alter the ride.
If you like your S-type the way it is, simply have the same size fret wire but in a harder material. That way, they should see you out.
https://www.theguitarengineer.co.uk/prices.html
Probably not worth it, unless you have an emotional attachment.
Re-fret worth having is going to be £225-£300 as a minimum.
If a cheap guitar, there are various new strat copy necks on eBay from uk sellers between £45-£90, some of which are really decent.
Edit as @lincolnblue I hadn't read your update whilst typing and posting this.
Appreciate the sentimental element.
If there's any shops or mates nearby to try other guitars, you could look up specs maybe. Probably going to end up at something med jumbo, unless you have specific want for skinny vintage or jumbo. A modern Jet is almost certainly going to be some sort of med jumbo.
It will feel different at first regardless, new frets with additional height, new setup and so on.
I would suggest contacting @FelineGuitars - I am sure Jonathan and team can either find you the fret size that matches your existing frets, or offer you suggestions. Their refret work is top notch too.
Slightly taller/wider than vintage - Stewmac 152
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
