FS - Fender Pure Vintage 65 Jazzmaster bridge
liftmanliftman Frets: 61
edited June 2022 in Parts £
Fender - £35
DD- HB101B ( '59 style for bridge )  £15 SOLD
DD- HB102N ( Jazz style for neck ) £15 SOLD
https://imgur.com/a/jAQW7PX
  • liftmanliftman Frets: 61
    bump
    bump
    bump
  • lovestrat74lovestrat74 Frets: 2542
    edited June 2022
    Does the jazzmaster pup come with cover and fixings?
    @funkfingers could I put this in the neck position? I mean sonically, would it work?
    No cover unfortsh , just four screws.
  • FunkfingersFunkfingers Frets: 14594
    Yeah but no but …
    Obviously, the pickup will work in any position. The polepiece spacing is the same for bridge and neck. The covers are the same size. There is not a massive difference in output between bridge and neck.
    The negative aspects are;
    1) The magnetic polarity and coil direction will not cancel hum when combined with a second JM bridge position pickup.
    2) If liftman's pickup has been removed from a Fender AVRI or AV guitar, the black conductor wire may be cut very short.
    If the black conductor is shortened, on a regular Jazzmaster, you might get away with grounding the pickup to the chassis of the Rhythm Circuit slider switch.
    edited June 2022
    Yeah but no but …
    OK thanks for the Wiz.
    @liftman I think I'll give it a miss, but thanks for the info :+1:
    Yeah but no but …
    Yes it is off an AVRI with short conductor wire. No probs @lovestrat74 .
    bump
