I recently bought 280 quids worth of Alvarez Delta 00 acoustic guitar a few weeks ago and have been endlessly fiddling about with it.
I’ve got rid of some sharp fret ends, polished the frets, sanded the saddle till the action is where I want it and I’m just waiting for my head to shrink back down to normal size after recklessly and stupidly drilling a bleeding great hole in the bottom and fitting a Gretsch Deltoluxe pickup.
It looks good, plays good and sounds great and I’m wondering what other needless tinkering I can perform next.
What about swapping the plastic bridge pins for bone or wood?
Will they make a difference? Is it a worthwhile upgrade? Or am I just jerking off?
Any opinions welcome.
personally I dont think it makes a great deal of difference "tone wise" certainly not for brass/metal - tho there are those that will say it does.......... its more cosmetic for my ears (see what I did there !!! )
you'd be better off getting a bone nut and saddle, or some new strings
The only type that sound different are brass. I did some fairly careful comparisons, just swapping three pins at a time, with plastic, wood, bone and brass, and could hear no difference at all except with the brass ones.
Ebay mark7777_1
bone.
Could be just me, but I've never been a huge fan of unnecessary DIY trepanning ...
I don't think it can be weight alone, or changing just three pins would affect all the strings. (Half as much as changing all six.)
I wouldn't say terrible, but not to my liking - definitely an increase in upper-mid 'zing'.
This. But do try to compare them accurately, or you're likely to fool yourself. If you change the pins at the same time as the strings, of course you will think the new ones sound brighter, whatever the material .
When I was doing the comparisons I purposely kept the same strings on, and just swapped three of the pins at once, leaving the other three strings as a 'control' so I could see if the three with changed pins sounded different. I changed them in both top three/bottom three, and an alternating pattern.
Personally, unless you really want that upper-mid thing that the brass ones seem to do, I would just pick the ones you like the look of and either don't worry about it, or convince yourself they sound better .
At the end of the day strings and saddle material make a *far* bigger difference anyway.
Then it's which ever sounds best with Monel strings - which I love - on each particular instrument. So my strings aren't changing, they're always Martin MM12.
Listening (with only my ears and brain only obviously - pitch is individual and subjective) I've never found much difference between plastic and tusq. Mostly I work through but settle on bone. On one guitar it (Yamaha FG5) its brass. Bone seems to give a very slightly cleaner sound. Ebony can be more woody on an instrument which isn't very woody and brass is unquestionably brighter.
The biggest and most noticeable timbre change with all of these different pins is brass. Otherwise, as others have said, fiddling with pins is not often a huge game changer. But it's fun and cheap so good luck!
Top fave? Those bone pins with abalone dot inlays on the top. Usually about a tenner a set on Amazon (c.f. Liquid Metal which will set you back a ton).
(Apologies to non-cockneys. tenner = £10. ton = £100. ............and that info will cost you a pony my son).
I'd say that would make about as much difference
