I'm probably around the 5th owner and there are various degree's of workmanship inside,from flux splatter to evidence of
a too hot iron being used.
What I would like to achieve is to be able to dial in the boost to taste,add the footswitch capability and replace the cheap
oval 15" speaker with a better one,could just do with a bit of guidance.........
That pot looks more like 470Kohm. That value is rather high for a meaningful variable boost control - but it might be a useful place to start! You would quickly find the resistance range you really wanted and then you could swap the pot to something more useful.
Do I take it the stereo jack is mounted but not wired...?
Can we assume you're handy with a soldering iron?
Are you ok reading schematics like the one I posted above? If so, a really useful exercise would be to go over the whole amp & check out what's been modified & what hasn't!!
A simple solid state relay would work well and be small or you can get relay boards to mount a larger one.
You can probably get a DC power source from the heaters.
470k will act like a on off switch and not give you the range you want, but you could put a 120k resistor in parallel with it to make it more useful
But seriously I have bought a different speaker to try so I would like to just add a resistor on the boost switch.
Which terminals do I add it to and any particular way around?
I'll then button it up and see how the speaker is before I check out the schematic for future upgrades.
Thanks
L upper L centre L lower etc;
At present the ground wire is to L upper and the wire to the board is L centre.
Can you state using this method of id where the zist goes,sorry for the game show approach but I want to get it right.
Also which value zister will remove the most boost.....4.7K or 10K.
Thanks for your patience......
Both 4.7k & 10k are too small values. I suspect the 'boost' will be negligible. Almost certainly need something more like 47k or 100k. Lower value resistor = less boost (currently a pure short (very low resistance) is no boost & open circuit (infinite resistance) is the full boost). Hope this helps.
