But, yes, you really should have checked when you got it home so that you could take advantage of the store's returns policy, if you needed to
Plug your guitar into an amp and tap the bridge where the two E strings cross the bridge if you can hear sound from both
side of the saddle then the pick would be OK. The other thing is you may have a dirty contact if you haven't used the guitar
for a while and as you will know the low E string will vibrate more with a lower frequency than the high E string it just might
be possible there is an intermittent contact and when you strum the guitar makes and breaks so use some contact cleaner
on Jack socket also check the push connect contact to the tone controls.
I don't think the under saddle pick up is broken because the lead for the pick up leaves the pick up on the treble side.
You can lift out the bridge and do the same test but make a note which way around it goes for intonation reasons.
Here is the Fishman link.... https://www.fishman.com/wp-content/uploads/2020/06/Sonicore-Pickup-Install-Reference-Guide.pdf
Hi I stand corrected here is another Fishman diagram and it does show the pickup installed from the bass side not the
treble side. https://www.fishman.com/wp-content/uploads/2020/06/sonitone_guitar_install_guide.pdf
so may be as mentioned in previous post there may be break in pick up !
I would tap bridge on treble side to se if you can hear anything ! But it still could be bad contact so clean and check connections
as well.
Hope this helps.
It’s one of the most common problems with undersaddle strip pickups.
