In fact, if you only want to switch between them and never combine the two, it will work anyway - it's just the middle position which won't work properly with one of each.
The signal paths are entirely discrete from each other. The nearest that they might come to each other is at the tip and ring contacts of an output jack socket.
Driving the passive pickup into that pot designed for the active pickup will take an awful lot of top end off the passive pickup so you would need 2 pots really
The only thing it would share with active bridge pickup is the input jack.
Could that work?
Fully discrete circuitry would not but, instead, you need two cables and some line selecting or mixing device before the signals reach your amplification.
Something like this maybe
Truth is I’ve never had a guitar with active pickups in the 30 odd years I’ve been playing but bought one recently with the intention of swapping them out, but it turns out I actually quite like the sound of it in the bridge.
Ive got a Humbucker and single coil ready to drop in so might give that a go and see how it sounds as I could always switch it back again.
Or is there such a thing as an active pickup that can mimic the sound of a regular Tele neck pickup for that lovely chimney yet slightly angry tone?
