in the UK we are 240v and this accounts for many fender amps like running hot and shorter tube life !
I have done the 240v Mod on my Fender 68 Custom Princeton Reverb & my Fender Blues Junior.
I can't find any details on how to do this on my Pro Junior !
I know there is nothing available on how to do this on a Pro Junior so there may not be anything on the amp you are looking
to buy ! Hope this helps.
The colour coding is consistent across *most* Fender models but not all, so don’t assume anything without checking one way or the other.
It won’t void the warranty as long as you make sure you put it back if you ever need to send it for repair .
Rift Amplification
Brackley, Northamptonshire
www.riftamps.co.uk
This seems like an interesting article on the subject
(Just measured mine - 239V.)
But this is.
Although it misses out a crucial piece of information - the reason Fender set their amps for 230V is not because they're wrong or badly designed, it's because it's a regulatory requirement for electrical goods sold in the EU. In fact, fitting the 'legacy' 240V tap is *good* design because it means they can be corrected after sale.
The reason why it's particularly a problem for valve amps is because valve equipment (including CRT TV/monitors) is unusual in stepping *up* the voltage internally rather than down in almost every other type of electronics. Although the proportional change is the same - ie 5% more supply voltage produces 5% more internal voltage - because power dissipation is dependent on the *square* of voltage, it rises much faster than the voltage itself.
The EU 230V label is a kludge, a form of words used to embrace everything found here and on the continent without having to change a thing..... the legal spec states 230v +10% -6%, allowing the European 220v system to remain at 220v and UK to remain at 240v. Viewed from on high, all voltages appear to have been "harmonised".
I've spent the best part of the last thirty-five years moving around Europe, the USA and elsewhere, using every voltage available in three continents - including some very brown stuff, coming off the flakiest supplies imaginable at live events, and occasionally with the sort of "earth/ground" that could be more properly described as potting compost.
As a result, I've been hanging a lot of my gear (labelled 110V,120V, 220V, 230V and 240V) off large transformers for most of that time. I test wherever I go, and use the input voltage taps and choice of outputs to produce a slightly lower voltage than the amp being used actually requires.
Right here, right now, my mains measures 239-240V, and my transformer is outputting 219-220V to a Two Rock which is labelled 230V.
Also if you were a Fender Service agent they would send you the required doc's when requested.
What are you trying to figure out on yours?
I do yes!
