SOLD - Bareknuckle Humbucker Bridge 15.4k
BeardyAndyBeardyAndy Frets: 716
edited July 2022 in Parts £
Took this out of a recent PRS purchase as it's too hot for my taste.
Only BK pickup I can at 15.4k is the Crawler but I can't confirm this as they don't put the model on the pickups, it's the 6 string with chrome cover.
https://www.bareknucklepickups.co.uk/pickup/humbucker/crawler#pickupBuilderIframeLink
£100 posted. (Sorry about the dodgy 2nd pic, i'll improve it over the weekend! )
  • FunkfingersFunkfingers Frets: 14588
    The stock neck/Rhythm position humbucker should be a 58/15 S. If you take a DC resistance meter reading from that, your replacement bridge position pickup needs to be approximately 12% hotter.
    Typical PRS SE Singlecut pairs are 8k (N) and 9k (B).
    The BKP Crawler was tailor made for PRS Custom users, most obviously, Geoff Whitehorn. Should sell pretty quickly.  :)
  • BeardyAndyBeardyAndy Frets: 716
    Thanks. I've put a SD Antiquity in there, and will put my HB P90 in the neck spot at some point. Need to order a new harness first, that's clearly where they saved the money on the S2 Standards! :)
    SD Antiquity … HB P90 in the neck spot
    Smart choices.
    FWIIW, Oil City Winterizer II works nicely in the neck position of my S2 Singlecut.
    Is the stock neck pickup likely to be available to purchase?
    Smart choices.
    Could be, i don't suppose it'll effect the resale value much now that the bridge pickup is gone.
    Bump
