FS, Most of a nice Strat (GSP, GuitarBuild, Pribora, Wilkinson) + Ibanez-ish neck
DrBobDrBob Frets: 3011
edited July 2022 in Parts £
In a rare moment of clarity I’ve realised that I’ve actually moved house with some of these parts twice so it’s safe to say they’re not getting used anytime soon and I could really do with raising funds to buy a bike to get out and actually do some exercise so let’s see if we can get this stuff somewhere where it will actually get used
Beginning with most of a nice Strat Project;
1. GSP Basses Strat neck (SOLD)
Nice bit of wood here, we all know Graham makes lovely lovely things
https://i.imgur.com/aZnwfDy.jpg
Rosewood board over maple neck with what feels like some sort of oil/wipe on finish on the back of the neck
stats are
22 frets (I’m saying med/jumbo) have been used but good nick
Fingerboard Rad looks to be 9.5-10” ish
Nut width 42.6mm
Heel width , interestingly the fingerboard is actually 57mm wide but the maple heel has been taken down to fit a standard Fender 55.56mm
Depth at 1st fret 22.2mm
Depth at 12th fret 24.5mm
it’s a nice rounded “C” profile, bit chunkier than a Fender medium C but not massive
It fits the GuitarBuild body below perfectly
Its been previously fitted for Klusons, will come with the bushings fitted, little notch out just behind the nut slot and a a few little dings around the headstock perimeter
https://i.imgur.com/jCDT6BA.jpg
https://i.imgur.com/1Egeuws.jpg
Its a really nice solid neck from the hands of the mighty Graham
Any extra pics or detail please shout
£90 posted
2. Guitar Build Strat Body w/ Tort Plate
https://i.imgur.com/1RkLa0l.jpg
https://imgur.com/gallery/K1GgyGH
Right so nice, medium/light weight Strat body which I believe is from GuitaBuild, it’s been finished in Oly white but without grain filler so the grain pops through
https://i.imgur.com/JCwIjXh.jpg
https://i.imgur.com/Ak3DgVR.jpg
https://i.imgur.com/g0CiISZ.jpg
Looks great, bit different and really works with the included Tort plate
https://i.imgur.com/xMoTwqY.jpg
£85 posted
3.Pribora “Red & White” Strat Pickups (SOLD)
Handwoud by Alexander Pribora out in Russia, and I believe he pots them in wax from his fathers bees… Never installed cables never cut. Boutique quality for sub Tonerider money !
https://i.imgur.com/sZEZvh2.jpg
There’s few different demos of these on YT but here’s one from the man himself
https://youtu.be/_ufXBUDZLrg
£50 posted ?
4. Wilkinson WVP6 SB Strat trem
https://i.imgur.com/Ic5GzE0.jpg
Yep it’s the one with the 5 elongated holes & the one round hole allowing you to fit it to either 54 or 56mm spaced screw holes
Its got the real deal Steel trem block with staggered string holes
Its got the push fit trem arm plus tension adjustment
Its got the full set of claw, claw screws, springs & mounting screws
£20 posted
5. Ibanez-ish neck (needs frets & finishing)
Details on this are a bit hazy, not trying to mislead I promise just as I said, I’ve had some of this stuff kicking about for years so I’ve forgotten quite a lot of what I was told when buying this stuff ..
Its deffo not real Ibanez
https://i.imgur.com/gWu28Tb.jpg
Multi lam 24 fret I neck with AANJ type heel
specs are
Nut Width 42.3mm
Heel Width 58.6mm
Depth 1st Fret 19.4mm
Depth 12th Fret 21mm
Fingerboard Rad looks to be 16” ish but given it will need sanding before fretting I guess you could change that
It’s a bit rough
https://i.imgur.com/VB5JF51.jpg
https://i.imgur.com/VJiaETS.jpg
it’s been de fretted so will need re fret before you can use it and it will need sanding and a finish applied
https://i.imgur.com/hM3eGbH.jpg
https://i.imgur.com/NoIN9yk.jpg
https://i.imgur.com/EFfS5Ic.jpg
But could be made into something fairly classy I reckon !
£50 posted
any more pics or details please do shout
Cheers
  • mrkbmrkb Frets: 6937
    Hi,
    Do you know the weight of the strat body?
    Karma......
    Ebay mark7777_1
  • DrBobDrBob Frets: 3011
    I don’t have a working scale hang on I’ll see what I can do
    Bathroom scales are saying 2kg but I’m not sure how precise they are tbh
    Ok thanks, was looking to replace a 2,05kg body on current partscaster as its too heavy - so doesnt work for me. GLWS.
    Karma......
    Ebay mark7777_1
    So 5g isn’t enough of a saving ? Kidding I’m kidding
    sure are - it would be 50g ;)
    Karma......
    Ebay mark7777_1
    Well there you go ! That’s a further 45g of weight saved !
  • dallcorpdallcorp Frets: 139
    PM sent re neck.
    Strat neck that is
    That’s Strat neck & pickups sold pending the usual !
    Strat Neck, Pribora Pickups, Wilkinson Trem sold
    Bump for a nice Strat body in an unusual finish with a classy pickguard !
  • daveyhdaveyh Frets: 684
    What wood and finish is it?
    Now I knew this when I bought it. But that was 8 years ago. I’ve messaged the guy who I bought it from who I think did the finish, see if he can come up with anything
    Right he thinks it was it was Oly White Nitro that he applied over a non grain filled swamp ash body
    This is extremely tempting but I was after an alder body. I shall be thinking hard on this
    Full disclosure, I’ve just looked over it and the tremolo holes are only starter holes , You would have to drill them to depth
  • robinbowesrobinbowes Frets: 3057
    I'm tempted by the body, but what do you mean by this?
    R.
    R.
    R.
    I’ll get a picture when I’m back home in a bit !
    R.
    https://imgur.com/gallery/dD18igD
    So as you can see. all six holes are drilled but they’re only drilled to a depth of 3mm so you would need to drill deeper to install the trem screws.
    Also, I’ve just noticed, you would need to drill the two screws for the trem claw
