Arturia Studio
Great condition, has one or two very small marks on the front edge of you look close. Boxed in original packaging, come with x2 usb cables (c-c, a-c), power supply, test sheets, quick start guide and will be de registered before sending out. Both bought new by myself November 2021
I’m only selling as I’ve decided to get a SSL BIG SiX.
SOLD Studio - £550 posted
Prices assume PayPal gift or bank transfer. Goods and services is no problem if you need an invoice etc but please cover the extra fees.
Can take more photos if required
Ok, good news! I’ve recorded a loop from a SP404 into every pair of channels on the 8pre. 1/2 and 7/8 crackled when I adjusted the gain - but after a good twiddle of the knobs, NO CRACKLING! mp3 link below that goes through each channel twice. Excuse the clipping, but I needed to turn the knobs from 0-10 and only thought of using “PAD” half way through.
https://www.dropbox.com/s/f8g2ktyxygx7gsj/8pre test.mp3?dl=0Please excuse the odd question regarding the Studio. Are you able to confirm if the unit exposes all the ins to the DAW, or does it rely on its own software where you have to mix things, and only exposes a single set of ins to the DAW itself?
The reason is essentially that I'm blind, and I strongly doubt that the Fuse software is something I'll be able to use, but the Reaper, being my DAW of choice, is accessible to me .
Thanks
Hi there
I can select inputs 1 to 8 in Ableton with no problem. You would want to use the Arturia software to set up cue mixes and the reamping to 5-6 outputs. Also Monitoring mixes would be set up in the Arturia software.
Hope that helps
Cheers
Bruce
Good luck with the sale.
