Fussy about strings. Some are, some aren't. No, I don't mean players, I mean guitars. (Though I'm sure it's true of players too.)
Example: I've had 15 sets of strings on the cedar-top dreadnought since I started my string journal, and only gave one of them a really bad review, and even then I found a few nice things to say. I've had 17 sets on the Huon Pine Angel in that same period and disliked at least five of them (admittedly, I have tried a few of my wackiest string ideas out on the poor little thing). The rosewood Messiah is fussier about strings, and the Guild even more so.
I daresay we all accept the idea that different guitars get on well with different strings. But I'm starting to think that some guitars are easy-going by nature and will made a decent sort of sound regardless of the strings you strap them up with (OK, within reason), while others are more demanding.
I might even go further and suppose that this has a lot to do with treble response. The Messiah, the Angel and the Guild all have a lot of top end, and all three are string-fussy. Coincidence?
Another thought: maybe it is small guitars that are fussier. My two dreadnoughts and the WA May (which is almost dreadnought size) seem to be the most forgiving.
My point? Nothing really. Just thinking aloud. As always, your thoughts are welcome.
It's made up its mind that Elixir, Rotosound, John Pearse, are out, but it likes D'Addario EJ11, EJ16 and XT
Last time I re-strung it I tried Newtone Heritage 12s and texted a friend saying it was the best I'd heard it sound.
Will probably put some D'addario 11s on as I have a packet lying around, but will stick to the Newtones after that.
The Lowden has always had Elixir 12s and the reason is, it sounds so good. Why look further.
At the simplest level, you either like a set of strings or you don’t. The reason why strings sound different on different instruments is complex, and to give a detailed answer is beyond most people’s interest. A string on its own, when energised, will generate sufficient energy , but lack the surface area to create the movement of air , so we can hear it. So it is attached it to something that will move the air. The same note will sound very different on different instruments. Steel strung guitars use the same stings as used on pianos. For acoustic instruments, it is called a coupled system. That is to say, every component is responsible for the end result , sound . That includes fingernails , picks, bridges , soundboards , length of sting and a long list of other things . The way strings vibrate is also complex.Strings vibrate in different ways and produce a range of different sounds . My strings try to give a balance of gauge and tension across the entire set , when tuned to a specific tuning . What happens beyond the bridge is out of any string maker’s control.
I won't make my usually plea for everyone to try Monels at least once on any acoustic. Oops. Just did!
The same strings did sound quite good when I put them on a small-bodied all-mahogany guitar though.
I put them on the mahogany 00 mostly because I wanted to use it with a magnetic pickup, and it sounded better but still not quite as good acoustically as it did with PB.
Got them from Strings Direct mate. Same experience as you with two sets I bought elsewhere
