Best 12 string emulator pedal?
'Vot eva happened to the Transylvanian Tvist?'
  • stickyfiddlestickyfiddle Frets: 27126
    HX Stomp does a good 12-string sim.
    Otherwise I guess maybe POG?
  • ColsCols Frets: 7036
    Digitech Mosaic.  Really excellent emulation as long as you play the guitar like a 12 string (e.g. no bending notes).
    Any old chorus pedal with a little wobble would cover it.
    Feedback
  • Cheers. I've grabbed a secondhand Mosaic, I'll see how I get on with it.
  • SporkySporky Frets: 28457
    Roland VG with the hex pickup,  because they're the only ones that do unison on the top E and B.
  • prowlaprowla Frets: 4931
    I've got a Mosaic - it does sound rather nice.
    I know but it means adding the hex and I only need a 12 string for a couple of numbers.
    Good move.  Recommend keeping the level control below half way, above that the effect becomes a bit strident.
    Perhaps a disproportionate solution then!
    Variax?
    The POG I had did a decent enough job of it (though I ended up using it just for octave down)
