When the '4 Chord' is Minor
RockerRocker Frets: 4987
A friend showed me the chords for a song he is learning: 'Sad Cafe' by the Eagles.  This has the progression, B, E minor, F#, B.  The expected chords would be, B, E, F#, B.  The 4 Chord is minor in that song.  Likewise in 'Man of the World' by Peter Green, D, A, G minor, A, D.
Interesting how the playing of the 4 Chord in minor changes the mood and feel of the song [compared to playing it in major].  Perhaps some of our theory experts like @Viz might jump in and explain what is happening.  My theory knowledge is basic  but improving slightly....  Thanks.
Nil Satis Nisi Optimum
  • Danny1969Danny1969 Frets: 10443
    It’s a classic trick used by Beatles , Radiohead and all kinds of bands.
    It’s a borrowed chord, from the minor scale, very effective
  • The trick when it comes to using the 4 minor chord is to play it after the 4 major in a chord progression - and yep - there it is - you'll have heard the sound in countless hits.
  • octatonicoctatonic Frets: 33815
    I understand it as a modification of the Rhythm Changes, where you would move from the IV chord to the I chord via a iv chord.
    So,
    F major / F minor / | C / / /  ||
  • vizviz Frets: 10709
    edited September 2022
    As others have said. And I really like the long violin diad at the end of Oasis Look Back in Anger - it’s a lovely example. 4:20 here:
    https://youtu.be/cmpRLQZkTb8
    The only thing I can usefully add is that quite a lot of music in a major key has a minor 4 chord, not as the IV - iv thing, but as part of the mode. It happens to exist as the 5th mode of melodic minor (also called mixolydian b6), which has I ii(dim) iii(dim) iv v bVI(aug) bVII. It’s in loads of Duran Duran and Rachmaninov.
    The other nice thing in a IV-iv-I is to switch the iv with a bVII13. Like if you were doing D - Dm - A, you’d do D - G13 - A, where the G13 is 3 x 3 4 5 x. It’s not as tragic as the iv but it has a certain tenderness.
  • I'm trying to think how to word this as my chord naming skills are a bit out of practice. But generally whenever I play something on piano where the minor iv chord is used in a major key, as I often find it a bit overused, I tend to use the 7th chord of the flattened 7th note, if that makes sense.
    So say we are in G, instead of using a Cm as the iv chord, I would use F7, perhaps with an added 9th (g note). Probably quite similar to Viz's D->G13 thing
    soundcloud.com/thecolourbox-1
    Precisely the same!
    In terms of overused, Rachmaninov’s entire 3rd piano concerto (apart from the main theme) and 4th concerto use it. It infuses the whole piece. It’s a bit unsettling because you keep expecting it to resolve up a 4th.
  • CrankyCranky Frets: 2630
    Is this the one that’s called a “back door resolution”?
    Indeed!
    Although strictly speaking the proper correct one is iv-bVII7-I. Like in the 2nd line of Misty. “Cloud” at 00:30
    https://youtu.be/rPOlakkBlj8
    I’m saying it’s also just as lovely in a IV-bVII7-I. Or indeed a IV-bVII-vi, like after “nipping at your nose” in The Christmas Song, at 1:59 in this EXCELLENT rundown by Joel McCray of the chords of this gorgeous song.
