I myself find 12-53/54's to be a bit hard on the fingers tuned to EADGBE, I'd try dropping the strings two semitones in the meantime to see if it improves playability, but there's no harm in trying lighter strings, it might just need a tweak to the truss rod.
Check the nut height - simply fret each string at the third fret (so it's also resting on the second) and look at the gap between the string and the first fret. It should be tiny - less than about a quarter of the string diameter and possibly as small as a tenth of it. If it's bigger than this, the guitar will feel stiff and hard to play in the open chord positions.
Check the relief - hold the guitar in the playing position, fret the G string at the first fret and also hold it down at the 15th with your right hand. Look at the gap between the string and the 7th fret - it should be about half the G string diameter, or a bit less. If it's much bigger than this, the action will be far too high in the middle of the neck.
If the nut is too high it will need professional attention - deepening the nut grooves requires the right tools, and experience.
If the relief is too large, you can adjust it yourself if you have the right tool for the truss rod. Contrary to popular fearmongering the neck will not explode if you tighten it slightly yourself . It's actually very difficult to break one if you use the *correct* tool and don't apply obviously stupid amounts of force - but if in doubt, and especially if the nut is also too high, professional advice is best.
Bridge height is harder to assess, because the correct height is affected by both the nut and relief, so you can't easily check that unless both are already right.
Finally - yes, the string gauge may be too high for you. There's no rule that acoustics must be strung with suspension bridge cables, and also contrary to popular myth, using lighter ones will not instantly kill the tone. Many smaller and lighter-built guitars sound at least as good with lighter ones, even as light as 10s (the lightest common gauge), although you may lose some bottom-end... but it sounds like you may prefer that. 11s can be a good compromise, and usually have lower strings nearly (or exactly) the same gauges as 12s but with lighter high strings, which makes playing easier.
If you've checked the nut and the relief, and the nut is OK but the relief is slightly too great, I would probably try a set of 10s first - the lower tension will allow the neck to move backwards slightly by itself and a truss rod adjustment may not even be necessary.
Does that make any sense?
Acoustic purists will probably scoff, but I use 11s on a full-size dreadnought, and it doesn't sound thin or weak at all. There's far too much made of using the heaviest strings you can handle, in my opinion - in fact, for lightly-built guitars it can even be counterproductive, excessive tension can actually stiffen the top too much and restrict the volume and tone, not improve it.
I put a set of NT 12s on an old guitar recently to ease tension, then tried the NT 11s.
Both are excellent and have good string balance, but I think next time I'll go back to the 12s as I find the 11s a bit too rubber band-ish for my style.
Depends what you're looking for.
Good hunting!
http://www.theboxwoodchessmen.com/
https://www.facebook.com/tingiants/?view_public_for=231700547508938
This is one of the reasons I use Newtones, since I can order a set of 11s with the correct 23 gauge G.
I also use compensated saddles, which make a noticeable difference and aren’t expensive to have made if you can’t buy one which fits, or modify one yourself.
