Turned the magnet around in the Seth Lover of my Sheraton, sounds alright, takes a bit of getting used to with the vol controls as the volume swells on rollback for a couple of notches, when the vol controls are at unity, thats when you get the quacky out of phase sound. Will probably put it back to normal when I next change strings.
Im sure lots know how to do it but here goes in case anybody wan to try
1. Remove neck pickup ( or just pull out a bit if wires allow, mine did) take off pup cover
2. carefully remove the tape at both ends of the pup being carefull not to damage the thin wires.
3.Loosen the screws on the baseplate.
4. gently push out the long thin magnet halfway and with a marker, just mark the end.
5. remove the magnet Don't flip it over, simply turn it 180 and put back in with the marked end going in first.
Put it back together and have a quacking good time.
(the out of phase sound only works with the selector in the middle position)
"OUR TOSSPOT"
The handy thing about the magnet swap method is that you can do it with braided vintage-wired pickups.
This is actually the reverse of the PG mod but I tried the magnet flip and the reverse wiring on the bridge pickup of my 355 (they were out of phase (magnet) as stock).
The magnet flip definitely gives a more profound change though it took a couple of days to settle. With the reverse wiring there was still an out of phase sound with both pickups selected.
The only trouble is, even when it sounds good, it screams 'Peter Green' much as the in between sounds on a Strat scream 'Mark Knopfler'. Hence probably of limited use....
Anyway thanks to your info I thought I'd give it a go. Pretty happy with the result, just a couple of notes - my magnet wouldn't slide out.
The answer to this was to unscrew the 4 baseplate screws and the 6 adjustable pole piece screws. This allowed me to separate the bobbins and pull out the magnet and complete the job.
Cheers!
