Is it possible to de-Floyd a guitar?
There are some lovely instruments out there, which could get a new lease of life if it were possible (also advisable?) to swap out the Floyd system.
I have a lovely Yamaha 912 with a Floyd, I am just not sure about it, and it gets uncomfortable as rest my palm on it and the bass string bridge has a pointy corner and the adjusters are always in the way. It is also a bit of a faff too. Love the guitar, plays great, just not sure about the Floyd.
I keep seeing other things I like the look of with Floyds too, but...
What is the perceived wisdom? Or who has a clever idea to move beyond that?
There's been a related discussion on the Suhr Forum recently: http://online-discussion.com/Suhr/viewtopic.php?t=8370
An idea in there for a replacement nut.
Here's the (old) Pacifica neck joint:
http://i.ebayimg.com/00/s/MTIwMFgxNjAw/z/ihcAAOxy6~BR0Nth/$(KGrHqFHJEIFGvnvCv-tBR0Ntg46Kg~~60_1.JPG?set_id=880000500F
That was on all but the cheapest original Pacificas, I think. Certainly my 512 has it, as did a 1230S I played in a shop once.
The dimensions of licensed Floyds vary, unfortunately. I'd not bank on compatibility.
I'd agree with the idea of changing the guitar rather than spending heaps on it: second-hand Pacificas go for peanuts and are real bargains in terms of the quality you get for your money. Look for an 812 used, that'll have a vibrato you can set to float and pull up a bit. Or a 904 if you want something a little more vintage-specced.
Here's a 721 neck joint: http://i192.photobucket.com/albums/z30/Guitarlon/8e2ebc451fc3c7b5a0e682e3c6625871.jpg
http://i192.photobucket.com/albums/z30/Guitarlon/bebdf13ad938fb8c6cda8b3c25da4f25.jpg
http://i192.photobucket.com/albums/z30/Guitarlon/4385777523cb3e20fa54f536c69eedd9.jpg
Here's the thread: http://www.harmonycentral.com/t5/Electric-Guitars/NGD-Pacifica-721/td-p/34144664
Look what he paid: peanuts!
I also second his thoughts on looking into a used model of a different one. They're consistent.
And excellent.
I've not owned one, but came close to owning a 61...Something (611?). It had a bucker and p90, and was stunning but the guy pulled out of the deal sadly. I've played plenty of them, though, when testing amps and a few friends own them. One won't play anything else (seriously). He just replaces with his pickups of choice, and away he goes. Peanuts used, too!
In fact, they're so affordable used, I'd say keep your one and learn to live with the Floyd until you can afford a fixed bridge one.
Instagram
The old Floyd-removal question is a valid one, but there isn't really an economical way (bar the Schaller ICBM posted) of getting around it. There is a gap in the market for some kind of drop-in replacement, but as mentioned original Floyds, Schallers, Gotohs and Ibanez units all have different spacings and would probably be expensive...
Good luck what ever path you choose!
