That is odd since the 50 is/was AFAIK electrically identical to the HT-40 combo!
The latter might not be anything particularly special but I had not read anything that vitriolic about it!
I suspect the 50 head might have been faulty in some way, maybe someone had buggered about with the bias?
Dave.
Solid State comment very accurate
I bet it was faulty IF it was as bad as suggested.
I say this NOT to leap to the defence of a company I no longer work for and certainly have no financial interest in but from the position of pure logic.
I, and many other people were in the presence for several hours, several days a week of amplifiers of all sorts being put through their paces. In addition to the Blackstar range there were Marshall, Vox, Mesas, Soldanos and a few others I can't remember and some I had never seen!
In all that time (andf it is ongoing) the companies products MUST have stood up pretty well against the competition otherwise surely someone would have noticed?
Then there was a steady trickle of "famous faces" who were whisked off to the testing "studio". They all seemed quite happy?
I myself was charged with fitting a valve powered reverb tank in a 100watter for a very famous (now deceased) guitar person. HE did not send it back and call it ***T!
And lest you think reviewers and such just "wave things through" ? I recall an amp that was sent back as sounding far too bright. The guy was right. It specc'ed way out of line and was stuffed with the wrong cap.
***T'appen.
Dave.
I've had a HT5 and played through the HT40 for quite awhile, I didn't particularly like the tones but that's just my ears and my opinion.
Ok, sad to see you go.
I am not being defensive. I do not think Blackstar make the best amp in the world (nobody does!)
I was a great pains to point out that I am no longer associated with the company in any way. My comments are those of a technician. If someone came here and said they had played say an AC15 and it was "shit" and "cack" and a horrible sound that no one could possibly want I would immediately suspect a fault in the amplifier because I, and about a million+ techs in the world know these to be very acceptable amplifiers!
I shall give one more "technical" example. We had a Series One in with bad sound on one OD channel. It was a bit subtle and I (being mutton) could not hear it. But one of the diodes in a feedback loop was OC (broke actually) and that caused a very asymmetrical waveform which did not (I was told) sound at all nice! You could also see the fault on a scope.
So, I do not care the make of the amplifier. If someone comes here and says something that I KNOW is well built and has 100s of manhours of testing behind it, sounds crap, I SHALL defend it!
Dave. NB! Once again! R.E.T.I.R.E.D!
My music:- https://soundcloud.com/hubobulous
It's all about the drive for me - it's really easy to dial in a heavy tone.
You have to have thick skin to be a forumite! If not then best you leave all forums forever. People are different..have different ideas of what is good and what isn't...y'know "ones mans meat.." n all that.
Anyway....I really love the sounds I've heard on the HT Stage 60 in that range, not really heard any bad sounds on any Blackstar amp so far. So I now lust after a HT Stage and Artisan 15. The Artisan 15 for pure toanz to the boanz is definitely the mostest bestest favouritist for me tho.
I'm a vegetarian. Do I need to leave?
I really liked the artisan 100 I tried. Wouldn't mind knowing what sort of circuit it is, it sounded magnificent.
"I really liked the artisan 100 I tried. Wouldn't mind knowing what sort of circuit it is, it sounded magnificent."
Sorry, no can do! I CAN tell you that there is no magic circuitry in there, just solid, tried and tested amp ideas that have been around since the Dawn of Amp Time.
EL34s of course, fixed bias (25mA per valve*, CAN tell you that!) Then a gaggle of 83s in a very comprehensive filter/tone circuit and a presence control in the feedback loop.
Solid state rect rated at 1700V 25A iirc.
Very big traffs and a general BSH build. The amps are pretty indestructible, never known anything to fail save a valve even when some folks that should have known better drove the bllx off one with no load they just forked a couple of op valves and a fuse.
*Later down the line I found that some new valves were out of bias range and could not be quite pulled down to a 100mA total. Those qualified to work on amps will know how to deal with this.
Peeps say it takes pedals very well? Well you really would not want to run one at OP valve distortion in the pub? Not for long anyway!
Dave.
