NGD – I’ve just acquired a 7-year-old Chinese-built Takamine GD130ce – solid spruce top, laminated mahogany back and sides, one previous owner. It needs a modicum of tlc. My questions:
• What size spanner/wrench/Allen key is needed for truss rod adjustment? A previous post on the Acoustic Guitar Forum suggests 5 or 6 mm. Takamine’s website says ‘click here for instructions on adjusting Takamine’s two-way truss rod’ – but there’s no link.
• Should it have a serial number? If so, where is it? Takamine’s website doesn’t say anything about serial numbers for the G series. In fact, Its Support and Download Center appears to ignore the G series completely.
• Is there any documentation for the TP-4TD preamp?
• How can I get any of this information from Takamine?
• Or is there an independent Takamine users forum? Apparently there was once (Takamineforum.com), but it’s gone offline.
However, somers seem to be 3/16".
It is marked on the bottom of the interior label in tiny writing as "Made in Taiwan'.
My allen keys have vanished into an alternative dimension, so can't help you there, but the serial is on a top brace inside the soundhole toward the neck (see photo).
And yes, wiping the strings with a fluffy cloth is not a good idea
Edit: definitely a 5mm allen
It would seem that the G series either weren't stamped with a serial number or that the serial numbers applied are not reliable for dating them:
well done Bill , he has come up with a mine of info above
