I’ve been meaning to take my GS Mini to a tech to sort out the high action for a while. I bought it a couple of years ago and after a short honeymoon period I measured the action and compared it to a couple of other acoustics I have… it was around 3.5mm! As an interim measure I took a spare Tusq saddle I had lying around and sanded it down (keeping the original untouched). This improved things, although it’s still a little high and the break angle is just this side of acceptable - so the neck really needs to be sorted by replacing with the correct shims in the neck pocket for the original saddle.
When doing research into this I find that as it’s a relatively easy adjustment for a qualified tech, Taylor will apparently pay the tech to do it under warranty. Just wondering if anybody has had this done under warranty? I registered the guitar with Taylor and the tech is listed on their website.
No idea how you go about claiming it through Taylor, but if the worst comes to the worst it won't cost you an arm and a leg.
I don’t want to give the tech a call and sound like I’m trying to get out of paying him for doing the job! On the other hand, I shouldn’t have to pay for work that is covered by a warranty, cost of living crisis and all that. I’ll probably try and book it in and then mention it just in case.
I know of one but there must be others in the UK.
*assuming not caused by the owner!
Chris Andrews @CA Guitar works is gold.
Edited as (on reflection) it was unfair.
Taylor won’t do a warranty repair if they think it’s been in too humid an environment
If still not happy, we can give tech recommendations.
My GS Mini neck reset and set up....
Collecting on Saturday so fingers crossed
Any probs drop me a PM and I'll put you in touch with a guy I know is good. Saying that, should be fine - seems to know what he's doing in the video.
I know its an older thread but let me know if you need any help.
