It's all a lot of bollocks really. There isn't actually a law that says anything has to be PAT tested but it's recommended as it may help defend your position should something go wrong. There's no legal requirement to do it every year or even keep a record and plaster things with PAT stickers .. but again it's advised should something go wrong.
So I play the game as any band who does wedding venues and corporate functions has to generally mail in the PAT and PLI before the gig.
It's just an external visual thing and a basic wiring thing really. A PAT tester can't tell you something will stay safe even when it passes and a battery PAT tester may well pass an item who's chassis earth is hanging on by a thread. Some of the bigger units can damage devices in the insulation test as they can put out over 1KV
So be a competent person, inspect it visually, run the test, keep a record and sticker the gear up and that will generally be enough to keep everyone happy.
As Danny says the PAT thing is mostly bollocks but as you say a lot of venues say no green sticker no gig.
It is a good thing that you inspect your gear at least once properly every year, and also have an idea of what PAT is all about. The reason is if you get someone to do it for you, then you’ll know when he’s ripping you off testing stuff which doesn’t need testing. For example your pedal board, the pedals don’t fall under PAT however the power supply does.
As many people have said, there's no legal requirement to PAT test, and not really any such thing as a PAT test certificate, but you are legally responsible for making sure your gear is safe, and PAT testing is a goes a long way towards that.
I could gather the equipment together (most which is mine) and book a person to do the PAT testing. I'm currently up to about 50 to 60 items. This includes the PA, monitors, backline amps, but the bulk of it is the numerous mains extensions, IEC type leads and spares.
But then, I can't see how it would be easy to ensure 100% coverage, as it's a Jam Band type set up and someone might turn up with a new amplifier or extension lead etc
Can I really just buy a PAT test meter and do it myself? If so are there any recommendations for good meters.
The following is stated at the HSE site https://www.hse.gov.uk/electricity/faq-portable-appliance-testing.htm
"The person doing testing work needs to competent to do it. In many low-risk environments, a sensible (competent) member of staff can undertake visual inspections if they have enough knowledge and training. However, when undertaking combined inspection and testing, a greater level of knowledge and experience is needed, and the person will need:
- the right equipment to do the tests
- the ability to use this test equipment properly
- the ability to properly understand the test results"
I've got a degree in Electronics Engineering and I worked in the electronics industry for over 40 years culminating in engineering project management type roles, including overseeing product safety. But I don't have a piece of paper that says that I've undergone the specific training for PAT testing.There appear to be a number of online courses for a little as about £40. But are these really legit?
And at the end of the day, the acid test of your competence is that nobody uses dangerous kit and gets fried. With your level of skill and experience, if you’re confident it’s OK, then it probably is.
Is there a PAT test meter you might recommend? Some are just pass/fail and I think I'd feel more certain that I'd got clear evidence if the meter actually presented the results of the measurement so I could create a spreadsheet of the recorded values. Also, I guess the meters have to be calibrated yearly.
Based on all that I'm still weighing up whether it's best to do it myself or pay someone else to do it.
I can send you one of my PAT excel sheets you can blank out and use if needed.
Many thanks for that. I've actually got an example spreadsheet from a friend's son who does PAT testing, but he unfortunately lives too far away to do the testing himself. And I love doing spreadsheets
The ball ache of testing is the paperwork and this is where you have to make a choice between buying the software and a printer, which is often really expensive but saves a lot of effort, or doing it all by hand.
Knowing which class of equipment your testing and how to use the test equipment to test that item,is the important part of the testing, but not beyond the wit of anyone. This is the only qualification you need to be a competent PAT tester. No degree or other certification is necessary.
https://borrowedtime2.bandcamp.com/
If so, he either doesn’t know what he’s doing, or does but is deliberately falsifying the number of items in order to increase his fee.
Only mains-powered equipment and cables (if separate) need to, or in fact can, be tested.
