NBD Ric content
JCA2550JCA2550 Frets: 439
edited February 2023 in Bass
  • FunkfingersFunkfingers Frets: 14578
    Send it back. There's a fingerboard inlay missing!
  • ICBMICBM Frets: 72667
    They always miss out the 19th fret one :).
    Very nice! I'm not normally a fan of the black plastics, but it really suits that one.
  • That’s lush!!!!
  • prowlaprowla Frets: 4949
    I once thought of having an end-plate on the fretboard to make that last fret.
    The best basses money can buy!
  • JCA2550JCA2550 Frets: 439
    It also came with the white pickguard and (plastic) chrome pickup cover  so I might see which I prefer when I restring and set it up?
  • martmart Frets: 5205
    I recently swapped out the pickup cover for the pickup surround you have there, with the thumb recess. I would never swap back!
    The cover will probably get right in your way. I took it off my 4003 for exactly that reason - but oddly, when I swapped it for my 4001, which has the neck pickup closer to the fingerboard, the cover is just in the right place to rest my hand on for punky pick-thrashing… which is mostly what I do with it :).
    I think the white plate will look odd with the black truss rod cover.
    Curses! ICBM beat me to it again!
    IMO, the best place for black TRC and PG is on a black RIC. Like Jim Smith of Cardiacs.
    Finally, is that a revised bridge/tailpiece assembly I see?
  • I think I still want a Ric. I considered one when I went for my P but decided it was too esoteric to be my only instrument - and the one I'd properly learn on. But now I'm reasonably capable I'd be keen to have a couple of "other" basses. Ric, Jazz, something hollow & thumpy...
    A Decent Jazz Bass is a beatiful thing to play, so is a 5 string fretless, Dingwall etc.....
    https://www.rickysounds.co.uk/product/rickenbacker-4003v2-tailpiece/
    You would probably be surprised - they're more normal than you might think. The 'treble' pickup is actually quite like a P, as long as it doesn't have the vintage-style bass-cut cap on it. Modern RIC wiring has a pull-switch to engage or bypass it. I've modded the tone control on mine to do so progressively, which is much more useful in my opinion - the best sounds are in the middle. The neck pickup is very deep and smooth, ideal for McCartney-like melody playing.
    They also play effortlessly, and the apparently odd body shape is supremely comfortable either sitting or standing.
  • Yeah - thing is when they’ve been played by so many different folks (McCartney, Squire, Geddy Lee, Lenny, countless indie folks, etc) there’s no reason to believe it’s not a versatile instrument. And they’re super-cool, which never hurts
  • That’s lush!!!!
    It most certainly is
    If you must have sex with a frog, wear a condom. If you want the frog to have fun, rib it.
    I also have the Rickysounds pickup surround with the thumb recess but in black. IMO, the recess is about as much use as an ashtray on a motorcycle. OTOH, the surround blocks the air gap around the pickup, minimising the chances of accidentally damaging its coils.
  • SchnozzSchnozz Frets: 1964
    Did you get a white truss rod cover too?
    That's better (?)...
    Looks great either way!
    Getting a second truss rod cover is very surprising - they're worth a fortune on their own, especially the black ones which are much rarer and less commonly faked.
