My favourite strings were Savarez Cantiga - not cheap post Brexit of course. With strings it helps to know what you have and whether you want to go brighter/darker etc. D'Addario make a good neutral sounding string that is a good reference/starting point.
https://www.thefretboard.co.uk/discussion/comment/3519555/#Comment_3519555
As you
IMO it's feqqed!
Or you could just replace them - have a look on Amazon etc and see if you can spot some with the same baseplate style and screw positions. Many will have the more common 'hook' type keyshaft retainers where the sides of the plate are bent up, rather than a rivetted loop. These are usually perceived as 'cheaper' or 'lower quality', but in practice they work equally well and have the great advantage that you can change a damaged keyshaft without replacing the whole thing. (If the shaft is bent too badly to be straightened, or broken off.)
I have decided to take the easy option and replace the whole lot, give the guitar a proper clean/refresh and new strings.
Probably overkill but it'll be better in the long run and hopefully play/sound better. I'll even upload a photo or two when it's sorted out
Thanks to @JonnyBgoode also.
TBH it has exceeded my expectations and I've been enjoying a little bit of playing time with it every day.
Thanks again @danishbacon for helping me out
For Classical Guitars アーカイブ - G-GOTOH
Acquired from @danishbacon, along with some quality strings.
Another successful project completed
