FS. Two Rock Traditional Clean, RDA Dualist 6L6
Two Rock Traditional Clean 50W head . 2021. £2800 SOLD In excellent condition. Just serviced by Surrey Audioworks, but has had very light home use only since new. This is the 50W (2)6L6 dual tube SS rectified (fixed-bias/cathode bias switch) version. Tube driven analog Spring Reverb with Send and Return controls, Passive Effects Loop. High and low power mode switch. Can deliver/meet up within 2hr drive, don't want to post this one as it weights 19.5kg.
Hand-wired Dualist 6L6 amp head by RDA, 25W. Mint condition, limited home use only. £1500. Prefer collection from Epsom or London. ON HOLD
In Robs words:
The DUALIST is a switchable dual gain stage preamp followed by a vintage style Cathode biased output stage. This marries a versatile blues/rock preamp circuit with a range of classic Tweed style amp circuits from the early days of the electric guitar amplifier.
SINGLE’ mode employs a single twin-triode tube configured in a classic tone-stack utilising the Gain1, Treble, Middle and Bass controls. ‘DUAL’ mode, which is foot-switchable, pulls in a second twin-triode circuit controlled additionally by Gain2, Level and Filter controls. Pull-pots provide EQ tweaking by way of Bright and Fat functions. There is also an additional Boost function which gives a gain lift and a slight EQ shift and operates in both Single and Dual modes. A twin footswitch selects the Dual and Boost modes. Both SINGLE and DUAL modes utilise a long-delay tube Reverb and a global Master Volume.
Various demo's reviews on the tube -
http://www.rdamplification.co.uk/- Dimensions: 49cm wide x 26cm high x 25cm deep.
- Controls: front panel (left to right). Input, Single/Dual mode, Gain 1 (pull Bright), Treble, Bass (pull Fat), Middle (pull Boost), Gain 2, Gain 2 Level, Filter, Master Vol, Standby, Power.
- Tube config: 2x 6L6, 5x 12AX7
- FX Loop
- Foot-switchable
- Tube reverb and control
- 8/4ohms switch
6V6 Head (SOLD on REVERB)- Dimensions: 49cm wide x 27cm high x 25cm deep.
- Controls: front panel (left to right). Input, Gain 1 (pull Bright), Deep switch, fat switch, hot/cool switch, Treble, Bass, Middle (pull Boost), Gain 2, Gain 2 Level (pull dual mode), Master Vol, Standby, Power.
- Tube config: 2x 6V6, 5x 12AX7
- FX Loop
- Foot-switchable
- Gain 2 trim
- 8 ohms
