Given physics is it even possible to have low profile acoustic tiles for room acoustic treatment (not sound proofing).
I recently decorated our loft conversion (slanted ceiling on both sides). My son used it as his own living room/office/recording studio, but now he has moved out I might slowly start moving my own musical equiptment up there as my play room has been polluted by work thus killing inspiration.
Now I can just about stand up in the middle of the room, so low profile tiles would be required. I could make my own pannels out of rockwool, but these would just be too big.
I know the cheap foam ones are crap and do nothing. So any other suggestions that are not expensive snake oil.
A 4cm thick panel on 4cm standoffs has almost exactly the same effect as an 8cm thick panel.
If the problem is height then ignore the ceiling and have 4-5cm acoustic panels to the left and right of monitors and a thicker one at the back of the monitors (bass is omnidirectional) and the opposite side of the room.
Tbh for just playing music you need much less treatment than for recording/ accurate monitoring/mixing.
In my bedroom I have two 4cm canvas acoustic panels (one from GIK & one off etsy) with paintings printed on. They dont trap down far but do remove flutter echo (standing echos between two parallel surfaces - clap your hands in a small room, the short echo sounds like a ring modulator) and serve as decor too.
You simply cannot treat the frequency/time domain response of a small room in any positive way without lots of absorption. Physics is against you sadly.
If you simply don’t have the room then work with a decent set of headphones and a cross feed plugin like CanOpener..
Si
