Looking for some advice from the masses in terms of getting a new-to-us mixer.
We've been getting by with a 4 channel little Beringer thing for a while now, but time has come to upgrade to something a little better. That something would preferably have at least 8 XLR inputs, with onboard effects and would be analogue (or at least have faders for quickly changing levels mid-set if needed). However don't want some great hulking thing that struggles to fit in the car. Don't mind used - budget is £250-300.
So given all that, where should we be focussing our attention, in terms of boards / brands etc.
Has good quality sound, 3 aux outs, built in compression for some tracks, Plus effects aux.
ebay
ebay 2
You should be able to pick up a used one well within your budget.
There is a new one here for £359.
https://www.scan.co.uk/products/soundcraft-signature-12-mixing-desks-compact-analogue-mixer-12-channels-2-usb-inputs?utm_source=google&utm_medium=cpc&utm_campaign=feed_clicks&utm_content=surfaces_across_google&gclid=CjwKCAjw6IiiBhAOEiwALNqncUxE7F5kyUbVRwFKpsxurh5pSH1IEZnuYNxUeY5W7a2fpuw9hP6JJBoClAUQAvD_BwE
Good headroom, great EQ and generous Aux buses .... also VERY reliable
You're absolutely right - the quality of output is very much going to be determined by user, rather than board itself. That said, finding something easy to dial in and if necessary change on the fly (hence veering away from digital), whilst also being bulletproof is absolutely key.
Off to eBay for a MixWizard I go...
