Hi Ive decided to put my money where my mouth is & have one incoming on Monday it will be a great solution for me . Anyway here’s a thread on another forum with load of info
https://www.thegearpage.net/board/index.php?threads/nux-mighty-plug-pro.2343436/page-13there are a few claims of a high pitched whine so Will have to see how it behaves for me
if it’s bad it will be going back.
some good videos on it
RK Ronquilio is always good
https://youtu.be/67YIatGpXkgLeon Todd another fave of mine reviews it
https://youtu.be/EqJ76Sup7XcA Phillipino guy makes a live gig rig using it !!!
https://youtu.be/JjzL6hvVh1gapparently it’s class compliant so you could plug it into your iPad to record on a Daw such as Cubasis
besides setting automated preset changes in the app ,you can also set points in a track in logic using midi numbers to change patches .
im hoping mine doesn’t have the whine noise as it really does seem ideal
I really like mine. It has replaced my laptop and plugins as my home practice setup. Mainly for convenience but it does sound great too.
Switch the compressor effect off and the noise disappears. Or lower the compressor Level setting and the noise goes. Or switch to one of the other compressor models and the noise goes.
So some people's preferred patches may not create this issue. Or perhaps there are other combinations of FX settings that cause the same issue?
Duff programming, I guess.
(This is with my old Sennheiser HD433 headphones with TSR plug. I think I've got a pair of Bose with TSSR too; will try them.)
