I'd always thought this in the 'hell no!' category, along with putting steel strings on a classical and such like. But last night I needed a bottom 53 or 54 string for one of my acoustics, which was strung with 80/20s. All I had was a 53 PB, so I stuck it on and hoped for the best. Well, it sounds just fine. If there's any subtle difference between this and how an 80/20 53 would sound, I'm not sure my ear is sharp enough to catch it. Six strings all in 80/20 vs, six all PB, yes, I'm sure I could hear the difference, but with just one string? I can't hear it.
Thomastic is the best-known example. Their well-known Spectrum set mixes brass strings with phosphor bronze (and also round wound with flat) to (they say) produce a more even, better-balanced tone overall. From memory, you have two plain steels as usual, then three flats with a round wound E. Two of the four wound strings are phosphor bronze, two brass. (I forget which ones.) The result works well and is a reasonably popular choice, though very expensive like all Thomastic products. Does it actually work better than a standard all-the-same set? Not really, at least not in my opinion. Nice strings well-made but needlessly complicated. (Which is pretty much what you could say about most German engineering!)
I'm trying without success to remember the other brand of mixed-material strings I've tried. Bit of brain fade there and I'm away from home and my string database scribble.
I do find it odd that I've never thought to do it before - just to see what it sounded like. It's been one of those things I imagined one simply shouldn't do!
I actually prefer the brightness of 80/20s as I like 'sparkle.' That's assuming there is added sparkle - maybe the difference between PBs and 80/20s is more negligible than I had thought.
No, I think you're hearing it right - new 80/20s are really bright.
Do I prefer that sound? Not really, though it can be just right for some styles of music on some instruments. Similarly, the super-bright sound of new brass strings can be just right sometimes. It's not "horribly bright" unless you happen to want something else. It's just yet another colour in the diverse pallete of tones acoustic guitars provide.
