I'm on a mini quest right now to really develop my speed (mainly cos i just wanna have fun and shred, something i've never been able to do well). I'm a big fan of the likes of Sam Coulson - really like that rapid fire pentatonic stuff and like that its conceptually very simple.
Issue I'm having is finding a RH position that's comfortable, whilst also offering max speed. I find resting the heel of my hand on bass strings for muting and pinky on the pickguard to be most comfortable, but as i get fast I find my pink begins to push against pickguard and raise my wrist off strings slightly, causing background noise issues. I also find I have a wiff of Zakk Wylde to my speed picking technique, whereby it comes from the elbow a little, meaning my wrist is rubbing on the strings side-to-side, again creating muting issues.
Another issues is the side of my hand can very gently graze the strings by the bridge when playing at speed, creating an annoying "zing"/muted sound i don't want.
Fast, cross string alt picking is not something that comes naturally to me at all!
I would recommend familiarising yourself with Troy Grady's pick slanting analysis. You don't have to go deep, just the basic concept is enough
This is my go-to recommendation for learning or re-learning the basics
Sounds like you're primarily a USX player. What kind of thing are you trying to play and at what tempo? And, ultimately, any close-up playing clips?
- Even of number of notes per string: yay!
- Only two per string: meh...not enough time to settle on one string before you have to 'track' over to the next one
What's it like if you play the same speed/subdivisions but two of each note (or three or four)?If your speed picking motion has a bit of elbow in it (or like mine a LOT of elbow in it) then I find I really have to concentrate on making sure that elbow motion is still there when I'm practicing slowly, otherwise you're not practicing the same coordination slow as when you speed up. There's a natural tendency to use less elbow and more wrist when you play slowly because playing with your elbow slowly feels weird and unmusical, frankly, but that's the difference between playing slowly and "shredding in slow motion" as @Clarky would put it
So I filmed myself working on this 2NPS stuff. Have to say I'm amazed at how much my wrist and forearm are moving about at speed. You can also here how as I speed up my wrist drops and starts to mute B string.
Things I think are worth mentioning:
I use a bit of rotational forearm movement in my picking motion as well as side to side at the wrist, not sure if that's good for everyone though. Depending on what I'm doing there will be different amounts of each movement in the motion
I think the double escape is me attempting to counter my wrist dropping down the strings and muting them...which as you can hear happens anyway. I think when I get tense my wrist wants to flex and the heel of my hand wants to come down.
I always keep an eye on Ben Eller's YT channel. In the most recent exercise, which just happens to be about DPS, he's talking about using a 'practice mode' where you make really obvious motions to ingrain what you want your picking hand to do (obviously this doesn't quite gel with the 'start fast' CtC approach).
Final thought for now: try extending your practice run to cover more strings and don't loop from the top back round again without a brief pause...and maybe incorporate speed variances to give you a tiny breather, e.g.
I've come to the conclusion I just don't have the "fast-twitch" muscles in my fingers to ever get up to the speeds of a metal player. Anything faster than Jimmy Page has always eluded me.
I think that's just down to my physiology and metabolism - https://www.ncbi.nlm.nih.gov/pmc/articles/PMC6172607/
I can appear quick to the layman with techniques like sweeping, legato and banjo-rolling, but I feel ultrafast stuff will always be beyond my capabilities.
There must be individual speed limits...but they'll all be faster than you'd ever require in the real world. Not to sound like a CtC evangelist but there's a vid where, without a guitar in sight, they test certain relevant motions (such as knocking on a table) and it's clearly not hard to knock 8th notes well in excess of 200bpm. Once applied to the guitar, this equates to belting out 16th notes with alternate picking.
That sounds far more interesting to me: when your playing brings together a personal blend of techniques rather than just being an alternate picking shred-beast...as long as you're in charge of when it happens.
