it hums even when the unit is powered off, but if I take the plug out of the unit’s send socket, the hum stops.
Edit: the boss does need to be set to have a send/return block active, depending on how the HXFX virtual routing works you might need to do something similar.
I think I read it on the AMP1 Facebook group
It was ultimately the reason I ditched it.
Tried it again this morning - double checking cables and connections, and it doesn't seem quite so bad.... Might be the positioning of the amp or unit near the tele, or something?
I ended up with 2 of these on the board for my helix whihc sorted it right out
https://www.amazon.co.uk/Behringer-MICROHD-Hum-Destroyer-HD400/dp/B000KUD2G4/ref=asc_df_B000KUD2G4/?tag=googshopuk-21&linkCode=df0&hvadid=310853157999&hvpos=&hvnetw=g&hvrand=13881832976278141676&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1006693&hvtargid=pla-406644641495&psc=1
