After a couple of years gigging after the Covid holiday and being content with my ability, my playing has reached a plateau. But I am now looking to improve and 'level-up'. I have tried learning legato but I am finding I just cannot make the stretches across 5 or 6 frets. Tried learning a John Cordy legato pentatonic pattern and found it impossible to reach.
Do I just have short fingers or is there a way for me to achieve this style of playing?
Finger stretches? (yoga for guitarists)
Thinner guitar neck?
Narrower guitar neck?
Just play the higher frets?
Hand position? (tried a few positions but still can't make it)
Take up the tambourine instead?
and instead of thumb pad flat on the back of the neck, see what you can achieve with just the thumb tip touching the back of the neck.
if you find with the latter that you’re not getting enough finger pressure, then DONT try and do re your left fingers down, instead squeeze the guitar body with your right side elbow
Is not very comfy I use fingers 1 2 & 4 on these . Best to try & approach them further up the neck to get used to it and try doing the bigger stretches on 3 5 & 7 slowly . I find it helps with the guitar a lot higher than usual . 3 5 7 does get better with slow repetition daily ,don’t do too much though Some sort of stretching and massaging before you start too .
the ultimate answer is to set up your legato runs using the smaller stretches across 4 frets employing whatever means possible in 3 note per string and caged scales also incorporating slides in the 5 fret stretches or bigger .
I don’t have my Gibson or epiphone to hand at the moment but probably the very small incremental decrease in scale length might even help . Brilliant question though ,especially for us with older arms and hands .
am looking forward to seeing some answers on here
I’m sure though that there is a solution even if it means incorporating a deft slide into the run or a tap with a finger of the right hand (this is a good way to get round some stretches further up the fretboard , I’m sure there’s some in some van halen solos like beat it , or jump where he has a long stretch but you can get away with tapping it .
best of luck to you Paul
Just different positions.
12 14 16 is easy enough so maybe work out scale positions and play the easier pattern lower on the fretboard and leave the 5 fret shapes to above the 12th fret.
Works for me.
Might be some help in here
Awesome advice! Thanks so much. Lots to try. And it's good to know that there are others that find the big stretches tricky.
It's not expensive, helps with the physical aspect and, if practiced, will turn you into a REALLY good legato practitioner..
Si
Best thing is to go and try guitars with various necks and scale until you feel comfortable with a particular guitar.
Also don't think thin neck makes things easier sometimes these can cause strain on the hand so be open minded.
Hope this helps.
I do find that shifting from one stretch to another brings with it a whole new set of problems vs practicing the stretches individually. This particular problem really showcased itself when I was looking at Guthrie Govan's octave tapping arpeggio technique from Fives and Wonderful Slippery Thing. It wasn't the stretches on each string I was struggling with, it was always the string skip and fret jump that caused me issues.
I have since suspected that it may be first finger laziness but that remains to be confirmed.
