Heavy to thinner guage strings: truss rod adjustment needed?
Guitar in question is a 28 inch scale Ibanez RGIB6.  I've recently changed the strings from 65 to 11 (or in that ballpark) to 59 to 13.  Everything seems fine but I can apprecate that the tension is different now.  Do I have to adjust the truss rod? Ill check back in a day or two but it doesnt seem like Im getting choking out or fret buzz (bar the kinda new string style you can get).
Advice/thoughts welcome :+1:
  • mgawmgaw Frets: 5311
    Check the relief on your guitar.  Plenty of info on how to do that online
  • ICBMICBM Frets: 72860
    If the relief isn't excessive, and it's not rattling or buzzing in the lower positions, you don't need to adjust it.
    You may not - if the heavy strings are lighter and vice versa the total tension may be about the same, or close enough.
