You'll need the nut cut to accomodate otherwise the low B will be too thick.
If you'd use a B string, and wouldn't miss the G string, then go for it!
A reverse P pickup is better so the bit for the BE is closer to the bridge but a Jazz type pickup at the bridge is better still to allow for the definition from the B string.
If you already have a decent bass guitar, consider investing in a Hipshot X-Tender D-Tuner machinehead.
La Bella, Roto, D’addario flats all have shocking B strings.
Ernie Ball Group flats are very good and are far cheaper than Ti or Dunlops.
But rounds, even really old and dull rounds will be better. Can always do the hand cream thing to speed up that process.
Nil Satis Nisi Optimum
I used to use a 110 as a good compromise for E and D tuning.
