Complete 80W power amp section from Laney GC80 tested working
I recently acquired a Laney GC80 combo to upcycle into a valve amp. The power amp is in working order and it seems a shame to just strip it for parts. The filter caps appear fine and there is none of the hum you would expect if they had started to fail. I am offering it here for anyone that wants to use it as the basis of a project, or maybe to replace the power section in a dead solid state combo. I will provide a copy of the service manual but you will need decent electronics skills and probably some metalworking ability too!
£25 delivered in the UK.
These are extremely rugged and reliable amps which also sound very good, and loud for that generation of solid-state - the original combo it came from is comparable to a 50W 1x12" valve guitar amp. The power transistors and heatsink are over-engineered for the output power, and even the rectifier has a heatsink - that would be rare to find nowadays. If anyone's worried by what looks like a bulged end on the filter cap nearest the heatsink, it's just the plastic cover having got a bit too warm - a lot of them are like that but I've never seen the cap fail.
Also I double checked and the plastic end caps of the capacitors are both flat, you're just seeing a reflection of a ceiling light!
Even better . Funny how you get optical illusions like that...
