I originally used Jazz III picks and found the sharpened tips and small size was holding me back after using them for let's see 1994 til 2021..So 27 years,I could try and explain why but each to their own,we are all different..
So I experimented and found I really liked both the sound and feel of Herco Flex 75,,Holy Grails..
Compared to designer picks the difference isn't much..
I also continued to explore other picks,especially Dunlop Tortex and Nylon..
When I Started the Blue Tortex 1 mm fely about the same flexibility as the Herco Flex 75,,which is actually around 1mm not 0.75 mm...
At that point Green Tortex 0.88 felt clumsy ,got caught in the strings and sounded raspy..
A while later I found this wasn't the case the case anymore..
I also notice the Rhythm guitar sounded more open and just better..
I then found I could pick just as fast with a Yellow 0.73 Tortex as the Herco which is good because that is a good Vocal Accompaniment size on an acoustic guitar for me..
Now I'm finding I can pick as fast and tidily with an orange Tortex...60 mm
I'm even doing pretty well with a 60 mm nylon which is very flexible ..
Is this because my technique is getting better and I am not using force but technique to maneuver through the strings..
I used to find picking at speed pretty much impossible with a thinner pick..
Does being able to do this now have any advantages..?
Well apart from being able to use a thinner pick..
As for control....if you're practicing more and can play more precisely then that sounds good.
faster. I use standard Fender heavy shell picks.
Depends what you mean by fast though.
My rhythm is okay with medium picks ... but fast lead leads 'big' big pointy pick, big frets and big codpiece (I might have lied about one of those).
Big Codpieces can be stuffed with sports socks..
That Pick looks more like a Viking Axe Head..
Gold Hercos are a little bit too bendy for me,although the originals may have been..Stiffer/More Rigid..
............. Place Double Entendre here..
That's more Metal than Manowar that..
When you look at a sharp pointed narrow tipped plectrum..It can be very effective,but it is making you play a certain way,there is also less variation in how you can hold it for it to work properly./ no margin for error...There is no margin for error to find that a bigger tip has a wider contact surface.,,because there is none there.lol.. One instant solution is of course use the back edge..You have found another solution..Now we have came full circle..lol
I find meaning here..To many it would have been obvious in the first place..
