It's a pain in the arse when you wire up and it doesn't work!
Oh feckitty feck. Darned annoying/frustrating. I wired up and I'm getting no sound. I quadruple checked everything but it's not a happy bunny so I've disconnected the lot for now.
It's a complicated bastard, three P90s, Schaller megaswitch (which I had to wire the wrong way around, as it didn't fit the other way), piezo trem with board, 3 way switch, complicated jack plug!
Add into the mix the fact that the Piezo/pots/mini switch were all secondhand, not wired up brilliantly, and deviated a bit from the 'official' wiring in the way they were previously done. No guarantee that they all work properly!
Anyway, for now I'm just going to rewire with a standard switch, a new pot, new regular input jack and no piezo. Return to headscratching at a later date when I have finished setting up the rest of the guitar.
Disappointing day ...
  • FunkfingersFunkfingers Frets: 14474
    Are the magnetic and piezo signals fully discrete from each other, with individual output sockets, or do they get blended on a PCB?
  • axisusaxisus Frets: 28339
    Mini 3 way switch to have one, the other or both. Piezo has a PCB on its volume pot.
  • ICBMICBM Frets: 72442
    Test it in sections as you go along rather than assembling the whole complicated mess at once and hope it all works :).
    Yeah, I thought I'd wire up one component at a time and test!
  • Do you use a continuity checker/ ohm setting on a multimeter @axisus ?  Godsend when it comes to sorting out these kinds of thing.  It's usually a missing earth somewhere...
    I did a partial rewire last night, and yes I was using continuity checker/ohm setting. Still no joy. Having got to work I took a quick look at the original wiring for the powerbridge, and I missed the fact that the 9 pin jack plug goes to earth. So I'll be straight on the case with that when I get home.
    For what it's worth I figured it out. It's my first time wiring P90s with braided wires. What horrible things braided wires are! Yes, they look lovely but they are a pain in the arse to 'unpick', plus my woes were with them touching stuff that they shouldn't. The main issue was the neck pickup wire touching the underside of the middle pickup, but there is another slight issue which I bodged a bit for now. There's quite a few wires under the pickguard due to 3 pickups plus piezo, and something 'shorts' when I put the plate on and it compresses the wires a bit. For now I have stuck a bit of padding around the braids, which has cured it. One to look into next time I have it all apart.
    You need to push the braids back rather than unpicking them, and put some sleeving over the outside wherever there's a risk of them touching something. Other than that, it's nice wiring because the cloth-insulated type can't really be overheated and short, unlike plastic cables.
    I don't see how pushing them back would be possible! Looking online everyone says unpick them.
  • WezVWezV Frets: 16731
    They do push back quite easily, but the other way I sometimes do it is to loosen the braid a few cm from the end, just enough to pull the center wire through.
    Everyone online is wrong :). Just look at any older Gibson with factory wiring.
    Fair enough!
