I have 4 x outboard rack fx processors which I am trying to connect digitally to my home recording setup.
All 4 have AES/EBU (or AES3 if you prefer) XLR i/o, so does anyone know of a suitable AES interface which I could either connect to the optical ADAT on my TC Electronic Studio Konnekt 48 audio interface, or connect to my Windows 10 PC via some other method? Ideally I want to be able to use each fx processor individually, or all at once.
For info, I currently do have 3 of them connected to my audio interface via a combination of SPDIF and optical Toslink (a couple via coax to optical converters), but am having some clocking issues when trying to use everything together, so I'm trying to lose the converters and simplify things.
I appreciate there are mega-expensive new pro studio solutions out there, but I'm trying to do this on a budget if I can, so I'm happy to re-purpose older solutions. Ultimatelythough, I am prepared to replace my interface with something more modern if necessary (up to around £2k).
I think, therefore.... I... ummmm........
Axe FX III, Eventide Orville, Lexicon PCM81 and Two Notes Torpedo Studio, in a TC Studio Konnekt 48 audio interface.
If you want to save time, last paragraph has what I think you should do.
AES3 (AES/EBU) is a professional digital format.
The reason you are having issues is you are converting AES3 to S/PDIF and optical and it is just a big mess because you don't have any way to clock them properly. Professional studios will usually employ wordclock to keep multiple digital devices in sync but that needs to be planned properly.
The Axe FX III doesn't have wordclock, which is a serious limitation here and means you cannot do that. Or if you do it then the Axe FX III won't be part of it. The AFX is also fixed at 48kHz which is an annoying limitation. I've never understood why Cliff does that.
So, how are you connecting the equipment?
For instance, what is the clock master?
Please be descriptive.
If it is the TC unit then are you connecting the digital outs from that to the digital inputs to the devices as well as the digital outputs from the devices to the digital inputs of the TC unit?
The truth is that for 99% of people the converters in their audio interfaces are good enough and you don't need to be using the digital IO.
Don't believe me, try this.
1. Record the same signal from the Axe FX III into the TC via AES (or S/PDIF) and via analogue.
2. Time align them (because latency might be different over analogue vs digital, by 2-3 samples usually)
3. Flip the phase on one of the tracks and see how they cancel.
Here we do use digital outputs for some of the digital equipment, but the MTRX II audio interface has SRC on input and we use wordclock for any equipment that has it.
In your situation I'd buy a good quality 8 channel analogue to digital converter that supports ADAT (assuming you aren't already using the ADAT in your TC) and connect all the devices over analogue. I have an Apogee Rosetta 800 for sale soon, or there are loads of cheaper 8 channel converters that will do the job. Insisting on using digital from the devices is jst a rod for your own back with minimal or no sonic advantage.
OK, just to confirm that you have a BIDIRECTIONAL connection between all the digital devices?
So two S/PDIF cables between the Axe FX and the TC?
and so on...
This is important to know.
If you are using the TC as the clock master then everything else has to slave to it.
They should not be set to internal.
Have you set the clock to s/pdif on all of the devices, esp the Orville and PCM81?
The CO2's work to a point but I think the issue is going to at least in part down to using those.
The more digital devices you have connected the more important wordclock will be.
Running multiple s/pdif connections (with embedded clock) and then converting them from coax to/from optical I am not surprised that eventually it falls over.
The Lynx AES16 card is fine, if a little old now.
But I wouldn't suggest using it in addition to the TC.
If you want to replace it entirely then fine, but running aggregate devices is usually a recipe for disaster.
Does it do everything else you need?
There isn't going to be a cheap way of doing this that doesn't have some element of compromise, I am afraid.
There are very few audio interfaces with a large number of AES/EBU connections.
The Avid MTRX II does it with an option card, RME used to have one card but it is discontinued and there is the Lynx.
In your position I'd get an 8 channel converter, connect it over ADAT (using BNC wordclock for sync) and use a 1/4 patch bay to switch between 'guitar' and 'studio' modes by patching a few cables, rather than having to unplug everything.
OK, this is a fun one to look at. Octatonic lays out the issues very clearly. 48Khz running as dictated by the AFX3.
RME do have the HDSPe AES which would handle four inputs at once. £855 from Scan, add in the DSub cable at around £70...
https://www.rme-audio.de/hdspe-aes.html
£855 from Scan. A suitable Dsub cable with 4 in and 4 out XLR connections for your external units is around £70 to £75.
https://www.rme-audio.de/aes-ebu-cables.html
How a DA/AD converter fits into this system, I am totally unsure. So I am unhelpful.
But consider the RME AIO Pro card. You have a digital breakout cable offering 1x AES i/o and 1x SPDIF i/o. That would take care of two of the units. I think you can run multiple cards if your PC can handle it, giving you 2x AES and 2x SPDIF inputs.
You'd also have the analog breakout cable options as well and you could chuck in the Arc control system.
