Aria Sinsonido Travel/Silent Electro Acoustic Guitar (Steel Strung) £275
The Aria AS-101S is the perfect guitar for travel or to practice quietly with, perfect those late night sessions when you don't want to wake anyone up, or a great solution to pack and take to hotels or even a sneaky lunchtime practice at work.
You can play it as it is - quiet but audible enough to hear what you're doing, or plug in headphones (not supplied) to hear the guitar via its pickup system which has volume and tone controls.
The design is ingenious, it all packs away into a padded bag (included) in a matter of seconds.
Body: Mahogany
Neck: Mahogany
Fingerboard: Rosewood
Number of Frets: 20
Scale Length: 650mm (25 - 1/2 inches)
Total Length: 850mm
Nut Width: 43mm
Weight: 1.7kg
Frame: Aluminum in Soft Rubber Tube
Pickups: Original Stereo Mic in Tube
Controls: Volume, Tone x2 (treble, bass)
Bridge: Original SoloEtte round type, Rosewood
Hardware: Black
Finishes: Mahogany (MH),Piano Black (PNBK)
Accessories: Carry Bag
Currently set up with 12s, it has a super low and comfy action. The great thing about these is that it is easy to adjust the action as the bridge height can be raised or lowered via knobs at either end - no need for an expensive set up.
These are no longer made and the nearest equivalent is probably the much more expensive Yamaha range.
Collection from Plymouth, or will post for free.
Practice those fingerstyle Christmas tunes without annoying everyone :-)
