Can anyone walk me through setting up an Akai mini plus in Cubase 13?
I thought it would a good idea to set up a midi device primarily to get some drums going for practice rather than the click click click of a metronome, but if I can get keys going as well all the better.
Cubase doesn’t recognise the Akai but I can add it manually, and I can create a layout but that’s about as far as I can get on my own! So far I have been unable to assign any keys or get any sound from it. I have the manual but it may as well be in a foreign language, I’ve also searched for info online and forums but all I can find is for Cubase 12 and the interface has changed in 13 also there seems to be some programming involved (in the video I found).
My set up is - Steinberg interface, Cubase 13 (not sure if it’s Elements or AI) and an Akai mini plus. There is a DAW included with the Akai but I’d rather not use it if I can help it.
Full disclosure - I am an absolute numpty with this sort of stuff so please don’t assume I know anything about it other than the above!
There will be nothing "setup" for the Akai as standard except the keys and CCs for pitch and modulation within a VST instrument.
Anything you want it to control within Cubase itself will need to be setup under the MIDI Remote. It's fiddly but once it's done its done. There's some decent support on that on the Steinberg forums.
