You might not want to give the trade union-hating reactionary Mike Matthews your money, however if you buy a used one, your conscience will be clear.
One Control Purple Humper? Around the £100 mark new. Does actually seem to take a battery although it's a smallish pedal and does seem to be exactly what your are describing.
But your simplest solution is probably a TC Electronic Spark Boost (the full size version).
… but that’s now two votes for the TC Spark.
I have a tc electronic Classic Sustain + Parametric EQ pedal. Unfortunately for you, it is worth a fair bit more than one hundred Pounds. I need to check the specs to find out how many dB of boost it can provide.
