Recently acquired a pair of Bill Lawrence noiseless (humbucking) tele pickups, the bridge pickup is installed in my Esquire partscaster and is excellent.
However the neck pickup had both tails broken off and one of the coil to tail wires broken, this was clearly visible before I purchased the set and as a result I have no issues with the vendor.
Next step was to have a good look, removed the tape from the lower coil, unwind some wire and resolder to new tail, but still no continuity across the tails, inspected the top coil and have continuity, but nothing through the lower, base, coil, I was hoping my soldering iron would be hot enough to melt the wire coating and I’m now thinking this is where the fault lies, any suggestions welcome, thanks in advance, Mike B.
