Instagram is Rocknrollismyescape -
FOR SALE - Catalinbread Echorec, Sonic Blue classic player strat and a Digitech bad monkey
https://imgur.com/a/xPID9nB
The wire needs to go to either the bridge post insert or the tailpiece insert - if it's been pulled out at the body end this can be tricky - you need to remove the insert from the body, poke the wire back up the hole from the control cavity, strip the end, and tuck it down the side of the hole so the insert traps it in place and makes electrical contact.
Getting the post insert out without damaging anything needs a bit of care - surprisingly, the right tool is a large claw hammer or a small crowbar . With a piece of soft wood or folded thick cardboard to protect the body, and the post screwed about halfway into the insert, use it to carefully and slowly pull the insert out of the body, watching for finish or wood lifting around the sides. To get it back in, protect the top of the insert with some wood and drive it back using a medium-weight hammer.
The wiring actually looks OK in terms of the connections - however, there is *miles* too much excess cable, which even though it's shielded, will not help. In particular the pickup cables (which could also short against the pot terminals) and the yellow cables from the switch to the tone pot and the jack are far too long - the one from the switch to the tone pot is absolutely ridiculous. (I appreciate that you probably simply left the factory lengths here - they're notorious for this.) You need to shorten them to a sensible minimum where there's enough slack that you can move the wires about if you need to do any further work, but not much more than that.
Shortening the cabling may also actually improve the tone of the guitar - it can increase clarity quite noticeably.
I use a crowbar. I have done it with the guitar owner watching...
Yes, exactly. The electrical value is very small, but it seems to make a surprisingly large difference.
