Three switch TRS input midi pedal for Eventide Timefactor?
Creed_ClicksCreed_Clicks Frets: 1409
What might seem like a silly question, but as I have never bought a midi foot pedal before, I am not sure what to go for.
Basically, I am looking for a controller that will allow me to bank up, tap tempo, effect on/off. The other pedal on the Timefactor can be used for bank down. My idea is based on this video, but the company making this doesn't exist from what I can see.
So looking for options.
Would something like the GFI system triple switch work? https://www.gfisystem.com/triple-switch
I am not sure if this is what I should be looking for?
  • stickyfiddlestickyfiddle Frets: 27462
    edited December 2023
    You shoudn't need MIDI for that, just a simple 3-way aux.
    With my timelines I've actually always run a 2-way with the pedal in Bank mode, so you on the TF pedal itself you have Patch 1 / Patch 2 / Bank Up. Then set the external switch to Bank Down and Tap Tempo.
    I've used the Digitech FSX3 but currently have a 2-button homemade one.  Looks like the GFI one is the same thing in a different shape box :)
  • Bright Onion do an FS3X compatible triple switch ...
    It's a fairly simple circuit to DIY - a couple of diodes and the footswitches. I have the circuit diagram somewhere if you need it.
  • Paul_CPaul_C Frets: 7881
    Agreed, I made one when I had an MC6 - very simple.
    That looks like the solution! They also do a mini option, but might be too cramped for my size 11 feet!
