Stereo Reverb brain hurt
spev11spev11 Frets: 361
If I have two amps with effect loops and a stereo reverb (such as a RV6) can I run the A input/output to one amp loop and the other B imput/output to the other loop? Im sure I can and the cables would be a mess :) but my brain hurts thinking about it
  • SporkySporky Frets: 28869
    Yes, but I think you can pretty much guarantee ground loops unless you add some isolation.
  • spev11spev11 Frets: 361
    see I knew there was something I hadnt (couldnt) thought of
    It might be OK, but a couple of the Behringer HD400 hum destroyers (or similar) won't cost a lot and will make sure it all works nicely.
