I have asked about finding these, out something that would do this job elsewhere in the forum and other places on the web.
Most answers to this question on the web seem to fall into either no idea or try a r/c controller place with no hint of what to ask for.
Here goes:
After a lot of research I have found if I search for jst connectors, this is the generic brand name commondeered,a bit like hoover, then I can get a bit closer.
Next was to search for a two letter code like SH ,and number of pins.
There is a term 'pitch of pins that is a bit misleading. It means the distance between the centres of two adjacent pins in the connector. Nothing to do with angles.
Once I got to this stage I was able to find catalogues and search terms to find something to try for two wire pickups. I have bought some and will test with 2 wire pickups when they arrive and also use them for 4 wire on the occasions I want to add in other options until I find a 4 wire alternative.
Here is one such link to start your journey from a better place than I did.
Note: I visited the RS Glasgow shop on a Saturday morning and they only open Mon to Fri finding the correct item over the phone was pointless. Much like straying at photos of connectors not knowing anything.
