I put some 40-95's on the Jazz Bass tonight, which I was gonna do anyway and I've adjusted neck relief and string height. I'm quite pleased with the results as there is now only a slight buzz on the D string at 19th fret. Amplified it doesn't really show much. Not that I'd play up there much anyway.
I also inspected the frets to see if any had lifted a little and it appears not. I'd assume that would be easy to spot if so.
I might buy a fret rocker anyway to start with just to do my own checks. Will any do? Is there owt to avoid as I've seen prices vary from very cheap upwards.
Just another question: When checking with a Fret Rocker, would I need to remove the neck of the Guitar or Bass in question.
I've gotten the Jazz Bass almost perfect now. The action is good and I'm as good as rid of the buzz up the dusty end.
