Which basic distortion pedal?
TeyeplayerTeyeplayer Frets: 3215
edited December 2023 in FX
Inspired by the ‘what’s better than a rat?’ thread and the realisation that I have only ever owned overdrive and fuzz pedals, but not a ‘proper’ distortion pedal, I’ve found a new rabbit hole.
Currently on the board are an Abbott silicon fuzz, a Frederic effects Demon Fuzz, Boss OD3 and Fulltone fulldrive 3. So I don’t NEED anything, but you know it’s Christmas and I’m off work…stuff’s gonna happen (I was off ill the other week and ended up with a Taylor AD27e, I should never be allowed ‘free’ time).
I’ve set the limitations of under £100 and come from guitarguitar (as I’ve a £25 voucher to knock a few quid off). I’ve mainly been looking at the Boss DS1, Rat, or MXR 104. It’ll be going into an AC30 and Orange Tremlord if there are any tonal combinations best avoided. So what are your opinions? What am I missing? Throw them at me fretboard. 1
«13
  • monquixotemonquixote Frets: 17620
    SD-1 is an overdrive and great but not a distortion.
    My Favourites are the Boss DS-2 and the MXR Super Badass, but the Rat is also a classic (I'd advise one of the many variants with a choice of clipping diodes)
  • SD-1 is an overdrive and great but not a distortion.
    You are right, I meant DS1…still sleep deprived (thanks kids). :) Will go back and edit my post.
    Which of those would you say was your standout?
    The DS-2 is a brilliant classic distortion and it's turbo mode also adds a mid pushed fuzz layer (Dani California or Butler era Suede)
    The DS-1 is great but thinner and much harder to dial in.
    The Super Badass has a massive usable gain range and very powerful EQ. It also can do more "amp in a box" sounds than most distortions if required.
    Butler era Suede is a big influence, so that’s a great recommendation as it’s the right ballpark for me. Cheers.
    I’ll have a listen to some Super Badass demos too.
    If you search YT there are some demos of him showing the sound.
  • GoFishGoFish Frets: 1413
    Early 90s = DS-2
    80s (and then mid 90s) = RAT
    Dunno about the MXR
    Fender amps = DS-1
    Vox = RAT
    Dunno about the MXR
    I thik I may see an MXR in my future.
    Given your two amps, I would probably try a RAT first. With your budget, you could get a used RAT and a Boss. They don't sound similiar to me.
  • Rat!
    (I've not tries any of the others mentioned though, other than a DS-1 I didn't like)
  • LittlejonnyLittlejonny Frets: 134
    Don’t discount the Fender Full Moon if you want something restrained. But of course, there’s always…RAT
  • SporkySporky Frets: 28268
    MetalZone. Don't turn the dirt up too far, and make proper use of the EQ.
  • GrumpyrockerGrumpyrocker Frets: 4136
    Joyo Chopper-X
    A copy of the Horizon Apex-Preamp/MXR EVH 5150 Overdrive.
    Can often be had for around £45 and sounds fantastic. It even has a gate.
  • gusman2xgusman2x Frets: 921
    I’m enjoying my Joyo Uzi. Cheap as chips, and great amp distortion sounds.
  • Get a Rat or a DS-1. That way you can join in the hundreds of Internet arguments about which one is better.
  • EricTheWearyEricTheWeary Frets: 16295
    Pretty much exactly on budget would be the DOD Gunslinger which they are making again now. Fat yet spikey 70s valve distortion sounds (if that makes any sense), not compressed 80s metal anyway.
    I've had the MXR Super Badass 78 on my wanted list for a while, again to my ears and based on demos a bit less metal than the normal Super Badass.
  • ICBMICBM Frets: 72364
    The DS-2 is a great shout - it's got the same general characteristics as the DS-1 (which to me is the definitive pure distortion pedal), although it's not exactly the same even in mode 1 - and mode 2 is a useful extra.
    I also like the OS-2 Overdrive/Distortion, which is almost a SD-1 and DS-1 in the same box, with the ability to blend between them, so you can avoid (or mix ;) ) the boxiness of the SD-1 and the harshness of the DS-1.
    Did I say I like Boss pedals? :)
    The more sophisticated DS-1X is within your budget second hand too - I really like these, although in the end I decided I still prefer my old DF-2.
    I would have mentioned the DF-2 - it's still my favourite distortion pedal ever - but I doubt you could find one in working order for under £100 these days.
  • The DS-2 is what Butler used in Suede but, as I understand it, as an overdrive rather than main source of distortion.
  • I’m surprised nobody has mentioned the humble MXR Distortion+. It’s a classic.
    The 78 Badass is a Keeley DS-1
    The Super Badass is completely different
  • FezFez Frets: 525
    Back in the day I used a DS1 into an AC 30 & it sounded great don't have either of them now but I bought a DS1 a bit back for nostalgia, it doesn't make my gig board but I do love it.
    Don't touch that dial.
  • The DS-1 is a bona fide classic, beware if you get one that the tone control is spectacularly sensitive, any time I've owned one there's basically one spot where it sounds good, it's either too dark or too bright for 99% of the sweep. Despite that I would still recommend.
    The DS-2 is also a classic but i never got on with the second mode so I find it hard to recommend personally.
    The OS-2 is good for all the reasons ICBM says.
    As a slightly different recommendation, the Way Huge Fat Sandwich is an excellent distortion pedal and very tweakable.
  • Electro Harmonics flat iron fuzz has just sparked my interest. Apparently it’s their take on a rat and the clips sound decent. Under 70 quid too! I’m quite tempted.
    The Swamp City Shakers
