I play in a three piece covers band. Vocals, 2x guitar and backing tracks playing pubs and small clubs. Guitars are Helix direct to PA.
Presently I use a couple of Yamaha DXR12's and the mix is 'narrow stereo'. Usually feedback is the limiting factor rather than lack of headroom, so I'm not feeling the need for a louder system, but the Yamahas have limited bottom end.
I'm toying with the idea of ditching the Yamahas in favour of a single EV Evolve 50. It should still fit in the boot of my car and the sub is about the same weight as a single Yamaha. Going true mono isn't a concern.
Has anyone any real world experience of using these as a PA? They are clearly popular with DJ's but not much out there about bands.
First, on the Yams - if you haven’t done already have a play with the DSP settings on the back. I avoided this for a long time, preferring to rely on my mixer (dl1608/Qu-Pac) EQ but I sometimes struggled with boxy mid feedback. On a whim I set the DSP to “main” and the “boxy” was miraculously cleaned up and bottom end improved. I’ve always been suspicious of onboard EQ but this is very much worth exploring, particularly on small stages.
Evolve - the artist I work for uses well produced backing tracks and guest players, string section, etc. The Evolves handle the audio really well, project down the room great so long as there aren’t any physical blockages and the singer can stand in front of them and avoid the use of a separate monitor at surprisingly high levels.
However, like all mini line-arrays when they come to the limit of their grunt it’s very obvious and I suspect a single Evolve 50 won’t do the job of two well set-up dxr12’s.
You might like to consider the EV elx200-sp subs if space in the car allows. They’re light and loud, go plenty deep for pop and work well with the DXR8’s I put over them, negating the need for separate stands.
P.S.
I’m not far from you, if you’re ever rehearsing at a convenient time I’m happy to call by and let you hear what some subs might add, not the Evolves, unfortunately, they’re not mine - drop a PM.
