I'm building a mash up of a telecaster from off offcuts and scrap wood in my workshop. I'd like to install a strat neck pickup for that strat tone and a tele bridge pup for, well that tele tone with the usual tele controls and 3 way switch.
The choice of pups is a little overwhelming, being a p90 / humbucker player I'm out of my depth when it comes to regular single coils.
If you have any recomendations for a pair of pickups that will work ok together then please do post them here.
Nothing bright, I play blues and some Jazz so looking for a warm and clear sound.
(Ideally UK made - but not too spendy)
Thanks.
Neck - Oil City Californian. It uses longer magnets to make it sound like a Strat neck pickup.
Bridge - Oil City Wapping Wharf. This is a tapped single coil, giving two different Tele bridge sounds.
If your body is deep enough you can fit a five way superswitch and get: Bridge, Tapped Bridge, Both in parallel, Neck, Both in Series
will have a look at Oil city's website.
Maximise the sound options via either a Freeway 3B3 six-way or a Schaller Megaswitch M five-way switch (circuit diagram SS3).
I'd guess you'd probably want to go with a slightly warmer Strat pickup in the neck- assuming you're using a Tele bridge that tends to make the Strat pickup a little brighter (and with a little bit of a harder edge) than it'd be in a Strat with a trem. I would guess enamel winding wire and maybe softer/sweeter magnets (alnico 2 or 3).
Probably softer magnets in the bridge pickup too- I'm not that keen on mixing magnets, but that's just me.
Bloodstones are about the cheapest UK-made Strat and Tele pickups currently- excepting sales on places like Ebay from the likes of Catswhisker, Toltec etc.. You should be able to get both pickups for under £100. I haven't tried Bloodstone's Strat or Tele pickups but their humbuckers are great and I'd be shocked if their single coils aren't too.
I will be using a standard tele bridge, pics below.
From what I've read over the last day or 2, I agree that alnico 2 or 3 is probably the way to go.
Warm, smooth sounds are good, I play at home in the evenings only, can't deal with bright cutting treble.
I'll check out the pups from Alegree and Bloodstones.
(I also probably should've said that Bloodstones are about the cheapest UK-made pickups currently that I'm aware of, just in case there's something out there that I've missed!)
The guitar looks great so far, excellent work!
