Hopefully, the studs for the replacement bridge will directly retrofit the original inserts. Otherwise, you will have to draw the old ones out.
If the only thing wrong with the original bridge is saddle wear, it might be wiser to replace just the saddles.
Replacement saddles for the old bridge are not available.
What’s the post spacing on yours?
As Funkfingers said, what’s the fault with the existing one? I may have some saddles that will fit, although not certain... I think they're from an old Aria.
Aria are still using bridges at least quite close to the 80s Epiphone one - not sure if the post spacing is identical, but it may widen the search a bit.
https://ariaguitarsglobal.com/product/pe-350pf/
Out of interest, what is the post spacing (centre to centre)? That would confirm whether anything that comes up would fit at least the body inserts.
