If it's not that, it sounds like the oscillator isn't working. If this was a 80s Boss or Ibanez - or any other pedal of that era - I would suspect an electrolytic cap (probably the V/2 cap) as the most likely cause... these pedals are old enough now that the electrolytics are degrading and failing due to age. (If it is that, change all of them in the pedal - there are usually half a dozen or so, so it's not a huge job.)
I don't know if the Danelectro is old enough for that to be the top candidate, but the symptoms fit.
If it's neither of those it could be a cracked or cold solder joint somewhere, which might be tricky to find but usually not impossible.
